Hi, I get screen tearing as seen in this video that I posted in every game I play: https://www.youtube.com/watch?v=1Kp1VtqGQrE
I've tried multiple monitors, display port cables, mouses, gpus, cpus, every possibility you can think of I have tried to change. Temps are good, ram is good. No matter what I have changed or done, this tearing does not go away. 144h, 240hz, 360hz, 165hz, they're all the same and tear. Its accompanied by input lag in my mouse when the tearing shows up more, the more input lag I get.
Terrible screen tearing
Re: Terrible screen tearing
Lock the FPS to 3fps below the monitor's refresh rate and enable Freesync/G-sync.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
I have tried that at both 144,165 and 240hz and everything there's even a tiny fps drop the game feels like 20hz
I'ved used many monitors and hz , 144hz, 165, 240, 360 and they are all the same...
Make sure the game is configured to run in fullscreen mode (not "borderless fullscreen"). Enable g-sync and cap your FPS. In general, follow the guide here:thesoran wrote: ↑12 Jan 2023, 18:52Hi, I get screen tearing as seen in this video that I posted in every game I play: https://www.youtube.com/watch?v=1Kp1VtqGQrE
https://blurbusters.com/gsync/gsync101- ... -settings/
You can also try g-sync ON but with vsync OFF if you get stutters when there's FPS drops.
I appreciate your response, I have tried everything. Gsync on makes the game feel even worse when even a slight amount of frames drop. Unfortunately, it doesn't seem like there is a fix.RealNC wrote: ↑10 Mar 2023, 03:13Make sure the game is configured to run in fullscreen mode (not "borderless fullscreen"). Enable g-sync and cap your FPS. In general, follow the guide here:thesoran wrote: ↑12 Jan 2023, 18:52Hi, I get screen tearing as seen in this video that I posted in every game I play: https://www.youtube.com/watch?v=1Kp1VtqGQrE
Reason: Fix quote tag.
