Terrible screen tearing
Posted: 12 Jan 2023, 18:52
by thesoran
Hi, I get screen tearing as seen in this video that I posted in every game I play:
https://www.youtube.com/watch?v=1Kp1VtqGQrE
I've tried multiple monitors, display port cables, mouses, gpus, cpus, every possibility you can think of I have tried to change. Temps are good, ram is good. No matter what I have changed or done, this tearing does not go away. 144h, 240hz, 360hz, 165hz, they're all the same and tear. Its accompanied by input lag in my mouse when the tearing shows up more, the more input lag I get.
Re: Terrible screen tearing
Posted: 13 Jan 2023, 22:38
by Boomchakadah
Lock the FPS to 3fps below the monitor's refresh rate and enable Freesync/G-sync.
Posted: 14 Jan 2023, 23:14
by thesoran
I have tried that at both 144,165 and 240hz and everything there's even a tiny fps drop the game feels like 20hz
Posted: 15 Jan 2023, 07:21
by woodyfly
what monitor do u use
Posted: 10 Mar 2023, 02:14
by thesoran
I'ved used many monitors and hz , 144hz, 165, 240, 360 and they are all the same...
Posted: 10 Mar 2023, 03:13
by RealNC
thesoran wrote: ā12 Jan 2023, 18:52
Make sure the game is configured to run in fullscreen mode (not "borderless fullscreen"). Enable g-sync and cap your FPS. In general, follow the guide here:
https://blurbusters.com/gsync/gsync101- ... -settings/
You can also try g-sync ON but with vsync OFF if you get stutters when there's FPS drops.
Posted: 26 Mar 2023, 01:18
by thesoran
RealNC wrote: ā10 Mar 2023, 03:13
I appreciate your response, I have tried everything. Gsync on makes the game feel even worse when even a slight amount of frames drop. Unfortunately, it doesn't seem like there is a fix.
Posted: 28 Mar 2023, 04:50
by woodyfly
its the GPU bruh!
