XL2720z Problems
gonsass
XL2720z Problems
Post by gonsass » 06 Feb 2023, 21:34
I have an XL2720z, however it is showing these vertical lines only on half of the screen, I have already tested it at 60hz and 144hz and the problem continues, would it be a physical problem or with software can I solve it?
Video
https://youtube.com/shorts/_jLogwYkKL8?feature=share
Buchette
Re: XL2720z Problems
Post by Buchette » 12 Feb 2023, 03:15
Looks like hardware issue. Try with another cable and with another PC to confirm its a monitor fault.
If it is a panel fault, I had Line of dead pixels on mine and replaced the LCD panel. Thats an easy job, the thread of my issue and how i fixed it:
viewtopic.php?f=13&t=6954
