FPS & Variable refresh rate unable to sync in Dota 2
Posted: 11 Mar 2023, 19:58
Hello,
I recently bought Gigabyte G24F-2 monitor. FreeSync is enabled and G-sync under NVCP is also enabled for my RTX 2060. Monitor has 165hz refresh rate. The problem is whenever my fps drops below the max refresh rate, I face tearing plus micro stuttering which really annoys me and makes the game feel not so smooth. VRR is working and I have checked it via OSD RR counter and also via G-sync indicator.
Freesync doesn't seem to fulfill its purpose which is to match the refresh rate with my current fps which isn't dropping below 100 by any means so I am well in FreeSync/G-sync range.
The fps counter and refresh rate counter seems to mismatch which seems to cause tearing plus micro stuttering. I have already tried;
FreeSync + Vsync ON
FreeSync + Vsync ON + Frame limiter (-3 cap)
FreeSync + Vsync OFF + Frame limiter (-3 cap)
FreeSync + Vsync ON + Nvidia reflex boost
Actually everything that's been guided here on forums but FPS and RR doesn't seem to match once the FPS drops below my max refresh rate. Not sure if this issue is specific to Dota 2 or not.
Tried COD-MW2 and FreeSync works like a charm. Zero tearing or stutters.
FreeSync + Vsync ON
