Display Stream Compression and Display Cloning
evmadic
Post by evmadic » 26 Mar 2023, 05:40
I run a dual-pc set up for my gaming and streaming PCs. To do so, I clone my gaming display to my capture card.
My current gaming display is 1080p 240hz, and my capture card is 1080p 60hz.
Does anyone know if cloning a display adds signal bandwidth? The reason I ask is because I was thinking about upgrading to the Alienware 1080p 500hz display but I have some reservations about DisplayPort 1.4's bandwidth limitation of 32.4gbps.
To avoid active DSC, I would have to set the color depth factor to 8bpc: 1920x1080 @500hz w/CDF of 8 = 31.10 Gbps.
Even at 8bpc, if I account for another 60hz refresh rate to clone it, I'm well above DP 1.4's 32.4 Gbps limit and DSC will be active.
But I don't know if display cloning adds signal bandwidth. Can anyone confirm if it does?
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
