Reviews with different response times
boomlegshot
Post by boomlegshot » 26 Mar 2023, 09:49
There is a somewhat new budget 240hz VA monitor (25G3ZM). I've been checking a couple reviews on Youtube and they seem to have different results on their Response Time tables both using the same tool (OSRTT).
Both set on "Medium" overdrive but the avergage initial time almost doubles on one compared to the other. Why is this, is it the tool or unit variance?
Response time table by TechTeamGB (https://www.youtube.com/watch?v=rbq60r9N868)
Response times TechTeam.jpg (388.84 KiB) Viewed 642 times
Response time table by TotallyDubbedHD (https://www.youtube.com/watch?v=ihNqHxhSRrQ)
Response times TotallyDubbed.jpg (327.34 KiB) Viewed 642 times
axaro1
Re: Reviews with different response times
Post by axaro1 » 26 Mar 2023, 10:37
The reason is because one test is using RGB 5 tolerance and the other is using RGB 10 tolerance.
The RGB 5 tolerance test is far less forgiving.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
boomlegshot
Post by boomlegshot » 26 Mar 2023, 11:20
axaro1 wrote:
26 Mar 2023, 10:37
i see, good catch. i just barely learned how to read these tables with monitors unboxed video (https://www.youtube.com/watch?v=42IAbsMYxts) so i'm not very aware of this stuff. It was my bad for not paying attention to the tolerance part. So it's better when response times are measured low with lower tolerance.
Is this discernable to the eye? Is RGB tolerance of 10 testing good or bad?
Edit: Nvm I did find Blur Busters article about this (https://blurbusters.com/gtg-versus-mprt ... l-response)
Blur Busters GtG FAQ.png (153.56 KiB) Viewed 526 times
