this forum is awesome. I learned so much through reading articles, comments and generally lurking. Big thank you!
Long version
Now to my question:
I got a budget of around 500€ (I'm from germany, if that matters) and want to upgrade my Samsung XL2370 to something more up-to-date. I have a i5-3550 and a Radeon 7950, I plan to update my GPU with the next generation.
The general purpose of the monitor is mostly gaming, although I quite fancy a movie or one or two episodes of some series from time to time. If I had to put them into numbers, I would go with around 80-90% gaming, the rest of it are movies.
The games I play the most at the moment are CS:GO, League of Legends and Diablo 3. I have a very competitive mindset in the former two games.
In terms of "picture quality against motion clarity", I really thought that the Eizo FG2421 should be the best single monitor at the moment. As I read more about the topic (especially on this forum), he seems to have quite some inputlag (13-16ish?). As I have no comparison of the impact of input lag (my XL2370 is considered CRT-like), I'm unsure if that would be a problem for me in CS.
Considering the price tag, I could replace the FG2421 with a Benq XL2411Z and a nice IPS/PLS/VA panel monitor, used for games where motion blur is not that much of an issue or just as a dedicated second monitor / movie monitor.
Why not a single XL2411Z? I'm very very biased towards TN having bad colors (the Xl2370 has horrible, washed out colors). My friend has the Asus VG248QE and the colors were okay-ish and I'm unsure if the BenQ delivers more punch in that regard or if I'm just better off with a dedicated tryhard monitor and a dedicated "look at those colors" monitor.
TL;DR Version
- Old Monitor: Samsung XL2370
- Want to buy: Eizo FG2421
- Budget: Around 500€
- Games: CS:GO, League of Legends, Diablo 3. First two with a strong competitive focus. (80-90% usage)
- Movies/Series (10-20% usage)
- Unsure if Eizo inputlag throws me off
- Therefore: FG2421 or BenQ XL2411Z and a second IPS/PLS/VA panel monitor?
