Hello Everyone,
i have the following problem when i create a custom resolution with 2.880x1.620@85Hz it won´t show up ingame. On the otherside 2.880x1.620@60Hz shows up ingame also 2.400x1.350@100Hz but not 2.400x1.350@102Hz.
Maybe it´s because in the Windows Display Settings there are only 60,100,120,144hz predefined ?
Anybody have this problem too? because i want the 85Hz ingame with downsampling?
Any Solution ?
Thank you in advance
BenQ 2720Z - Downsampling Resolution not showing ingame
Re: BenQ 2720Z - Downsampling Resolution not showing ingame
You need to mention which games.
Many games start up well with custom resolutions.
One technique that can also be done is to make the custom refresh rate the only refresh rate available for a specific resolution. E.g. Remove 100Hz but keep 102Hz.
Hey i tested it with Counter Strike: GO and Diablo 3.
How do i make it the only available refresh rate ?
Start up is not the problem. I can´t choose the custom resolution ingame if not a standard refresh rate is choosed. !
Thx in advance !
Thx in advance !
