Hello all,
I've recently buyed a new AOC 24g2zu and I have a lot of horizontal and vertical black lines on this monitor The monitor still works at 240hz with mbr on or off like usually, but the screen is almost entirely affected by those lines.
I'm now on another 165hz display but I wanted to know if I can fix that by myself ?
This problem isn't caused by the hdmi cable or the Display Port cable since when I turn on the monitor with just the power cable connected, this problem is still here. I tried with an other power cable, same issue.
Arround one hour after removing all the cables from this monitor, I retried to reconnected my pc and console with this monitor and everything was fine again, the problem was temporary fixed for arround 20 minutes; but now those black bars are back.
So, if you know how to help me, I'll be glad to read you !
Thanks in advance !
[HELP] AOC 24g2zu lines appearing on screen
Re: [HELP] AOC 24g2zu lines appearing on screen
You can't fix that. Return it.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
