XL2540K vs 2566k
hyyliiight
XL2540K vs 2566k
Post by hyyliiight » 01 Jun 2023, 02:47
Hello guys, i am playing mainly pubg. My fps fluctuate between 160-300 / Most of the the Time between 180-220. I currently Play on a xl2746s on 1728x1080 Cru with larger verticals that my Pixel clock ist around 590. Playing without dyac or any Blur red. Or Sync. Playing Uncapped.
My question is: the 27“ is a Little to Big for me and want to Play on 24,5“. As you See my Stats of FPS Im thinking if the 2566k is a good Choice because i cant maintain +300fps. So was thinking of 2540k because its cheaper and dont have dyac what i anyways dont use.
Thank you for your tips
daviddave1
Re: XL2540K vs 2566k
Post by daviddave1 » 01 Jun 2023, 17:59
The XL2456K is good also. Did u see TGTLN's video on it with the best settings? https://www.youtube.com/watch?v=0wpokGq ... nnel=TGLTN ? ( also check out is other setting videos for Nvidia settings and PUBG itself)
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
Boomchakadah
Post by Boomchakadah » 03 Jun 2023, 00:17
XL2540k
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
