stiletto666
Post
by stiletto666 » 08 Jun 2023, 18:28
masterblaster wrote: ↑08 Jun 2023, 18:10
The XG249CM and XG2431 are very similar. I had both for about a month. I only liked the XG249CM a little better because it had some nice color vibrance options and crosshairs. I was not huge on the strobing on the XG2431 because its pretty dim. In terms for raw performance though both monitors are pretty good. I couldn't really tell a difference. Both fast, both responsive. Input lag seemed about the same.
What do u think about this one? seems thats its a newer model of that monitors with the same panel ???
Jossua
Post
by Jossua » 09 Jun 2023, 06:59
Tiberiusmoon wrote: ↑08 Jun 2023, 18:00
Jossua wrote: ↑08 Jun 2023, 17:50
Unfortunately the XG249CM is not on the rtings
Ah my bad, I was looking at a different model.
ELMB sync should still be good tho.
Thanks You
Jossua
Post
by Jossua » 09 Jun 2023, 07:05
Thank you, I'll take the cheaper between the two
