How do I fix screen tearing on an ASUS laptop?
DumbBot25
Post by DumbBot25 » 13 Jun 2023, 21:34
Dunno if this is the right place to post this.
I have a TUF Dash F15 2021 (FX516PM) which, according to the ASUS site, has an Adaptive Sync screen.
I have Adaptive Sync turned on in Intel Graphics Command Center, along with VRR in Windows Settings, but that does not get rid of screen tearing.
I've also tried forcing VSync on via NVIDIA Control Panel, but that does not seem to do anything on this laptop.
Edit: It only happens when playing games. No tearing in desktop.
Graphics Drivers and Windows are up to date.
Any suggestions?
Boomchakadah
Re: How do I fix screen tearing on an ASUS laptop?
Post by Boomchakadah » 16 Jun 2023, 10:56
If it looks like this, https://www.reddit.com/r/ASUS/comments/ ... ing_issue/ that's a hardware defect. Contact ASUS for a repair.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
DumbBot25
Post by DumbBot25 » 16 Jun 2023, 21:31
Boomchakadah wrote:
16 Jun 2023, 10:56
Nope, not like that. Just normal screen tearing.
Boomchakadah
Post by Boomchakadah » 17 Jun 2023, 00:15
Reinstall both the Nvidia GPU and intel iGPU drivers using DDU. https://www.youtube.com/watch?v=FPqUeU09cf8&pp=ygUDZGR1
If your laptop supports G-sync, enable it in the Nvidia control panel. if not, enable adaptive sync in the intel control panel.
Make sure the fps is below your monitors refresh rate.
DumbBot25
Post by DumbBot25 » 17 Jun 2023, 01:27
Boomchakadah wrote:
17 Jun 2023, 00:15
I've already done all of that.
- I deleted both NVIDIA and Intel Drivers via DDU
- I tried drivers from MyAsus as well as drivers from the manufacturer.
- I used RTSS to cap FPS to 141 (The laptop monitor is 144hz)
- Adaptive Sync is already enabled in Intel Graphics Command Center, and the laptop does not support G-Sync.
Screen tearing is still there.
Boomchakadah
Post by Boomchakadah » 30 Jun 2023, 00:16
DumbBot25 wrote:
17 Jun 2023, 01:27
Boomchakadah wrote:
17 Jun 2023, 00:15
Return it or contact ASUS for a repair/replacement.
