VG279QM vs G24F in competitive?
Yes, I know that the VG279QM has a higher refresh rate (280 Hz), while the G24F (1) works without problems at 183 hertz (stock 170, but you can set it manually to 183 and then even the more aggressive OD Balance works without visible overshoot), but the G24F has a faster response. When I tried to compare the video of ufo test vg279qm with 80 OD from YouTube, it seemed to me that although Asus does not have much visible ghosting, the image is much more blurry in motion compared to the G24F. Or will a higher refresh rate still overcome these shortcomings? And what about situations when the game will be 180 fps or less, which monitor will be better then? Well, the image quality, as I understand it, is better in the G24F
