After doing all sort of tests, with both MPC-BE and PotPlayer, and all possible combinations of video decoders (MPC, Built-in, LAV, etc) and video renderers ( EVR, Direct3D 9 and 11, MadVR, MPC ) I *always* suffer dropped frames in video playback if I have HAGS enabled ( Windows 11 23H2 Build 22631 ).
It's specially noticeable when using motion interpolation software like DmitriRender.
Video playback is ok when HAGS is disabled.
I would turn that shit off permanently, but you are FORCED to enable it if you want to use DLSS3 Frame Generation, like I need to do to be able to play Alan Wake 2 smoothly.
To enable or disable HAGS it says you need a full reboot of the computer, which makes this whole process a total pain in the ass...
So, any idea why HAGS makes dropped frames in video playback or how to solve it?
Is there any way to enable/disable HAGS without having to do a full reboot of the computer?
Any way to use DLSS 3 Frame Generation with HAGS disabled?
Dropped frames in video playback when enabling HAGS
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
