Gigabyte M27Q X Or LG 27GR83Q-B?
StinkyFart
Post by StinkyFart » 29 Feb 2024, 00:02
Hello all, I'm in the market for a new setup entirely and my new pc will be able to consistently hit 240hz. After blowing my entire budget on the pc itself, I was stuck between these two options for a 1440p 240hz monitor. I've heard good things about both and I was leaning more towards the M27Q X for its price but I've seen people complaing about the panel and QC. The LG is also nice but at a higher premium but would the price difference (~$130) be worth the upgrade? I've checked RTNGS' reviews on both and I'm simply torn. I mainly play FPS games like CS and R6 that require low latency and low motion blur.
If all else fails, are there better options around the $400-500 range? Thanks.
Talonrahl
Re: Gigabyte M27Q X Or LG 27GR83Q-B?
Post by Talonrahl » 03 Apr 2024, 08:31
Bump. If you get a response to this I want to know too. I’m looking for a non flickering 240hz monitor to work with gsync.
hayaya
Post by hayaya » 04 Apr 2024, 22:06
both displays have review on rtings, and their response time @ max refresh is basically the same, so i dont think +$130 would be worth if thats the primary concern.
posting your region might help others help you find a monitor because pricing and availability is not the same everywhere
M27Q (rev 2.0 :oops: :cry: )
past: random Kogan VA monitor (same panel as Viotek GN24C),
Philips 276E8VJSB
