What's the highest Hz the PG27AQN can do at 1440p with DSC turned off?
Bandwith wise DP 1.4 should do something like 290Hz at 8bit?
Would appreciate if users could try this out and report back
PG27AQN/XG27AQM DSC questions
VG259QM the GOAT
Re: PG27AQN max Hz with DSC off?
It's 240hz as far as I'm aware.
So no custom resolutions with CRU to maximise bandwith without DSC?
VG259QM the GOAT
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Thanks for the info!
I have another question related to DSC.
I got a XG27AQM and it still shows DSR when i put it in 270Hz 10bit RGB. Shouldn't it max out the bandwith, enable DSC and disable DSR?
There is no DSC toggle in the menu. Is it always running DSC, even in 8bit?
VG259QM the GOAT
There's no info I can find on DSC functionality for the XG27AQM, and I don't own it, so can't test.
