Hello,
I have a problem where the games keep scaling for some reason and I don't understand why. The resolution of the monitor and the resolution in the games are the same. So in theory it shouldn't be scaling, right? But every time I change adjust desktop size and position in NVCP the games are feels much different, so I think it's scaling. For example: if I'm use gpu scaling games are slower but if I'm use display scaling games feels faster. I can't write it more accurate, just feels like something is not okay. The reason I asked it because I have a couple of ideas what can cause it:
-High-dpi override (I have a dell g2723H 27" 1920x1080) I know its not a high dpi monitor, but I got this idea from nvidia support.
-Disable fullscreen optimization
-Windows size is on default 100%. But once I tried custom size 100% and then games were again feels different.
-Windows game mode
I know I have to try it myself and I will know, but I don't know how games should look if they don't scale and there's too many option that I have to try. Does anyone have any another idea what could be causing this? Most of the time I play rocket league, so that's why I can see it if the game is weird.
Thank you!
Windows scaling every game that I play
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
