Ok it's now clear why people keep asking for these ridiculous monitors. High hz don't mean high frame rates! High hz without a matching frame rate adds NOTHING and can even be detrimental. High hz by themselves don't:Edmond wrote:You want high framerates? Gratz - you can get a 200hz monitor now.
reduce reaction time
reduce input lag
reduce persistence blur
reduce stutter
High frame rates do those things people want. They represent real-time updates. Hz just flash the updates on screen, and btw, flashing the same frame update over and over has NO benefit visually or performance-wise! You just get blurry double vision motion studder on screen (the detrimental part). Everybody's seen that happen. So, a 144 hz monitor paired with a card that only puts out 60 fps gets you less than nothing. Things will look and perform much better if the refresh is more in line with capablities of your card. G-sync does help the stutter thing so, 3840x2160 at a paltry 20fps might look half decent nowadays. It doesn't fix the persistence blur and lag. Dollars to donuts few people know that.
So why buy a monitor with 1ms response time and a ton of low frame rate persistance blur. Defeats the purpose.
Why buy a 144 high hz monitor with a resolution that forces your card to a stuttering 60 fps? Beats me.
