Anyone have some good Videos, Documents, Guides, etc. For learning about building/modding, understanding, editting / making firmware and the like for Displays? I mean all kinds too (Beginner, Intermediate, High-Level) though with more of a focus on beginner and intermediate.
-edit-
Clarification I mean guides on building/modding, understanding Displays
and
Self Teaching about Display Building/modding etc
Re: Self Teaching about Display Building/modding etc
i think it's too hard to modify firmware and easier will be to find source code then modify it and compile.
Often the firmware is protected in such a way that it's basically impossible to read from the IC, and I don't think the source code is ever made public. Usually people get the firmware when an update is pushed from the manufacturer. At that point, you reverse engineering the assembly code, which is NOT something a beginner will be able to do.Q83Ia7ta wrote:i think it's too hard to modify firmware and easier will be to find source code then modify it and compile.
I editted the main post for clarification
yo, I'd really like to learn. Just need the right resources.
- lexlazootin
i feel like it's the sort of thing you won't find guides on, but if you believe in it enough you will find a way.
What you're asking is generalized and not specific enough to post in-depth about, mostly due to not knowing what sort of knowledge base you already have, but here are a couple of places you could start:
• CRU - Custom Resolution Utility by ToastyX | http://www.monitortests.com/forum/Threa ... tility-CRU ... the link goes to the general support thread about what/how to use it. I haven't read anything on it in years, but I use the utility all the time. Very nice tool.
• Monitor Asset Manager 2.9 by EnTech Taiwan | http://www.entechtaiwan.com/util/moninfo.shtm ... Not a lot of support for it, but it does a lot of stuff.
Those are software solutions for modding, hardware modding sort of requires some trial and error, but I know there are some guys on this forum that can probably point you in the right direction. There is another forum around, where guys do some cool stuff. Don't really want to link to it from BlurBusters though. Don't want to step on any toes. Trying googling some random keywords and add an "HF" to it. There have been some cool projects done over there. Nuff said.
