Hi all! I was really exited to get my new 120hz tv hooked up as a monitor for my new PC rig! It's looking great even at 60hz. However I cant seem to get it anywhere above 60hz without frame skips.. I created a custom resolution in nVidia control panel, 1920x1080x120hz, and it runs fine even in games vsync'd at 120FPS, but skipping every other frame according to the tests.. I also tried it at the lowest resolution (720p) and it would not go above 60fps even still. What do I need to do to get the true 120hz without frameskips?
I have one monitor running GTX760>HDMI>e390ia1
Second monitor running on the onboard Intel HD 530 build into skylate i7 cpu >HDMI>e390ia1
Neither of these monitors will go above 60hz on either graphics card. Did I get scammed?
Can't get 120hz monitor above 60hz without frameskips
Re: Can't get 120hz monitor above 60hz without frameskips
Most TVs only do 120 hz interpolation, and I think that's the case for yours. The panel does 120 hz, but the control board actually only takes 60 hz input.colby wrote:Hi all! I was really exited to get my new 120hz tv hooked up as a monitor for my new PC rig! It's looking great even at 60hz. However I cant seem to get it anywhere above 60hz without frame skips.. I created a custom resolution in nVidia control panel, 1920x1080x120hz, and it runs fine even in games vsync'd at 120FPS, but skipping every other frame according to the tests.. I also tried it at the lowest resolution (720p) and it would not go above 60fps even still. What do I need to do to get the true 120hz without frameskips?
I'm confused. So what's the difference between setting a normal monitor on interlaced mode, and my monitor? I tried setting it to 1080i (Interlaced), but the entire image vibrates up and down.aeliusg wrote:Most TVs only do 120 hz interpolation, and I think that's the case for yours. The panel does 120 hz, but the control board actually only takes 60 hz input.colby wrote:Hi all! I was really exited to get my new 120hz tv hooked up as a monitor for my new PC rig! It's looking great even at 60hz. However I cant seem to get it anywhere above 60hz without frame skips.. I created a custom resolution in nVidia control panel, 1920x1080x120hz, and it runs fine even in games vsync'd at 120FPS, but skipping every other frame according to the tests.. I also tried it at the lowest resolution (720p) and it would not go above 60fps even still. What do I need to do to get the true 120hz without frameskips?
So are you saying I got scammed? Theres no way to overclock the supposed 120hz monitor over 60hz, even 61hz? Thanks for the reply
A monitor that says 120 hz should do 120 hz. A TV? It should as well, but that's not how manufacturers treat their advertising terms. That model will never do real 120 hz right out of your PC.colby wrote:I'm confused. So what's the difference between setting a normal monitor on interlaced mode, and my monitor? I tried setting it to 1080i (Interlaced), but the entire image vibrates up and down.aeliusg wrote:Most TVs only do 120 hz interpolation, and I think that's the case for yours. The panel does 120 hz, but the control board actually only takes 60 hz input.colby wrote:Hi all! I was really exited to get my new 120hz tv hooked up as a monitor for my new PC rig! It's looking great even at 60hz. However I cant seem to get it anywhere above 60hz without frame skips.. I created a custom resolution in nVidia control panel, 1920x1080x120hz, and it runs fine even in games vsync'd at 120FPS, but skipping every other frame according to the tests.. I also tried it at the lowest resolution (720p) and it would not go above 60fps even still. What do I need to do to get the true 120hz without frameskips?
PC monitor that supports 120Hz out of the box.colby wrote:What do I need to do to get the true 120hz without frameskips?
No. There are only several TV models that support 120Hz (or more) from PC and afaik it's unofficial support.colby wrote:Did I get scammed?
Other 99% of TVs can't output 120Hz (or more) from PC.
About scam...Just look at the world's first 240 Hz drive gaming monitor http://gaming.eizo.com/products/foris_fg2421/
