Hello,
so i wanted to upgrade my current 60hz monitor for a while now since i heard that 120hz+ monitors truly make a huge difference in Counter-Strike:Global Offensive, the game im mainly playing right now.
Right now i have a 27" monitor and i really don't want to downgrade from that so i've looked around for some 27" 144hz monitors with some form of lightboost and i came across the BenQ XL2720Z but since i heard about all the strobe bug issues and it not even beeing available yet where i live(Germany) i am not too sure anymore.
Can you suggest me any good alternatives?
And one question i have with that new G-Sync coming out would that actually make a difference in a game like CS:GO?
Thanks!
27" Gaming Monitor mainly for CS:GO
Re: 27" Gaming Monitor mainly for CS:GO
If you are wanting a list of G-sync, current and upcoming, you'll find them here: http://www.blurbusters.com/gsync/list-o ... -monitors/
You'll see that two options you have (sticking to 1080p and 27") are the Philips 272G5DYEB and BENQ XL2720G. The BenQ is said to be coming out Q1, so sometime in Feb or March, at an unknown price. The Philips is reported to be $649 and coming out in "Spring", so you're probably looking at April-June time, though we'll see.
If you don't want to wait for G-Sync/ULMB monitors to take their time coming out, you can always purchase a Lightboost monitor now and use that, though be sure to read up on the pro's and cons of Lightboost as well. Here is a list of those:
http://www.blurbusters.com/faq/120hz-monitors/
If your system is able to maintain 120/144fps at your resolution then G-sync isn't going to help you as it behaves identical to vsync when framerate = refresh rate. In that situation strobing is definitely a good option. I would highly recommend G-sync if your framerate is generally lower than that, though most of the G-sync supported cards shouldn't have much trouble. It is quite expensive at the moment though.Juin wrote:And one question i have with that new G-Sync coming out would that actually make a difference in a game like CS:GO?
Thanks!
By now it's well known that capping the frame rate is a solution for this. G-Sync is going to help a lot with input lag. CS:GO is a game where you need very low levels of input lag, and the only way to achieve this with vsync is by capping FPS at least 1 frame below the monitor refresh rate. The result of that is stuttering. So G-Sync definitely helps.nimbulan wrote:If your system is able to maintain 120/144fps at your resolution then G-sync isn't going to help you as it behaves identical to vsync when framerate = refresh rate.
