Want a new monitor for mainly high competive play CSGO.
Playing on XL2410T 120hz monitor since 2011 and now looking for a worthy upgrade for even better experience for csgo.
Cant decide if a monitor like XL2411 or VG248QE, since its step up to 144hz from 120 and also support lightboost and low cost.
Or just step up and get Xl2546 or XB252Q. I play 40+ hours of csgo matches a week.
What to replace XL2410T?
- lexlazootin
Re: What to replace XL2410T?
Meh, buying a XL2411 or VG248QE would be good if you have a 60hz monitor but it's a small upgrade from 120hz. I wouldn't get the XL2411 either as the colors are awful and should be avoided at all cost.
But then you say you don't have much money and might want to get the 240hz monitors which are expensive.
I would recommend to get the XB252Q as you get the G-Sync chip which is great for it being well configured and from what i can see it's cheaper then the Benq. I have one and i love it.
