pg258Q vs PG279Q
Posted: 30 Oct 2017, 18:31
by Lucifer
hello
I'm interested in the Asus pg258q but I have a question
Does this monitor tire your eyes? Does it have a lot of brightness?
Is the IPS PG279Q better for the eyes?
sorry for my bad english
Re: pg258Q vs PG279Q
Posted: 30 Oct 2017, 19:05
by lexlazootin
I find it doesn't get dark enough and i have to turn down the Brightness and the Contrast at night.
It also has a low blue-light mode which is nice if you want that.
Posted: 31 Oct 2017, 16:15
by Lucifer
Thanks for your opinion
Do you think the PG279Q panel is better for the eyes? My eyes are very sensitive. I'm very hesitant.
Posted: 01 Nov 2017, 05:44
by lexlazootin
The PG279Q is a IPS panel, it will have better color accuracy and viewing angles. you can also lower the brightness to about half of the brightness of the PG258Q which will probably help you quite a bit. It also comes with the low blue light mode in the PG258Q.
Unless you REALLY want the 240hz the PG279Q is a great choice if you got the cash.
Posted: 01 Nov 2017, 08:33
by Lucifer
The problem is finding a PG279Q without failures XD
