Issues with display-output stuck to 200hz and no 240hz optn
Posted: 14 Nov 2017, 14:15
Hi.
I recently bought an Asus PG258 monitor, and have encountered issues when trying to set the output from my graphics card to values other than 200hz.
Gear: Asus PG258 connected with the included display port cable to a Nvidia Gforce gtx670 graphics card.
Problem 1: There is no option to set the video output to 240hz in windows nor the Nvidia control panel. I have tried adding a "custom" 240hz alternative to the list in the Nvidia control panel, but with luck (it disappears).
Problem 2: If I try to change to another frequency (60, 120, 144) in the control panel or windows (or both) the output changes back to 200hz either immediately or after changing between windows (ie. minimizing/maximizing a game or the control panel). These issues occur with gsync enabled and disabled. This means I am currently unable to activate ULMB for more than seconds at a time.
Problem 3: The built in fps-counter of the screen seems to produce nonsense numbers (far lower than the input to the screen)- I have no idea if this is somehow related to the other issues.
Stuff I've tried: Reinstalling nvidia drivers with and without "geforce experience", creating custom res/hz in nvidia control panel.
Any input is greatly appreciated. Thanks!
