Help me choose best colors and black G-sync monitor
Help!
Post by Help! » 21 Nov 2017, 20:08
Hello everyone, I am looking for the best G-sync monitor that has the best colors and black for up to $ 500. In my search I came across a monitor Acer Predator XB241YU some reviewers have found that the colors black and is close to the IPS. Thank you for your time and best regards
lexlazootin
Re: Help me choose best colors and black G-sync monitor
Post by lexlazootin » 21 Nov 2017, 23:09
That is going to be a pretty good monitor, it's the newer Acers so it's going to have the newer AUO panels, 'typically' because they all gaming monitors use AUO panels (120hz+), the newer the monitor are just going to have the most up to date revision.
You could get a IPS which might be more of your need but that will cost ya.
Help!
Post by Help! » 23 Nov 2017, 04:48
Some one have more opinions :)
Post by RealNC » 23 Nov 2017, 07:28
It doesn't look anyone owns this monitor here, so the reviews are the only thing you can take into account right now.
Note however, that for best blacks you'd need a VA panel, and for best colors an IPS. Given the thread title you're using ("best colors and black",) a TN panel is the LAST thing you would want.
Help!
Post by Help! » 23 Nov 2017, 09:47
RealNC wrote:It doesn't look anyone owns this monitor here, so the reviews are the only thing you can take into account right now.
I know :) But in the range up to $ 500 there is no IPS and VA monitor with 100+ hz G-sync so I'm looking for a TN model
Post by RealNC » 23 Nov 2017, 10:41
There are couple $500 VAs out there. Not sure how good they are. Examples are the Lenovo Y27g and Acer Predator Z271.
I don't know how good they are though. You'd need to look up reviews for them.
Edit: The Acer has a review on TFT Cental. It seems to be a good all-rounder monitor (good colors and blacks for movies and games, and 144Hz G-Sync with good enough response time and input lag for games.) So probably worth investigating. It is 27" though. I have a secondary 27" 1080p monitor myself, and it's perfectly fine for movies and games, but the desktop (mainly fonts) looks a bit grainy. But again, for movies and games, it's fine.
Help!
Post by Help! » 23 Nov 2017, 12:36
RealNC wrote:There are couple $500 VAs out there. Not sure how good they are. Examples are the Lenovo Y27g and Acer Predator Z271.
Acer Predator Z271 = 619$ , and Lenovo Y27g is a very bad monitor, lots of users write about pixel inversion, ghosting, clouding even you can see it on some youtube videos. That is why I am looking for the best (colors and black) monitor TN, 100+Hz, G-sync to $ 500
