suggested monitor resolution 1920x1080 help me pls :(((
i have benq 2540 monitör . "suggested monitor resolution 1920x1080" 1-2 second black screen . help me plssss ((
Re: suggested monitor resolution 1920x1080 help me pls :(((
Windows Desktop? Please go to "Change display settings" and make sure it's 1920x1080
Games? Please go into the game menu's and change resolution.
Did you ever do any tweaks (e.g. CRU)?
I can help you better if you provide more information, photographs, and detailed info. Sometimes there are 100 possible answers to a very brief question. There are many monitors, quirks, and solutions.
bro i have display port beacause 240 hz . i play profesyonel csgo player . 1920 no problem but i play very performance csgo 1024... 2-3 second black screen after popup "suggested monitor resolution 1920x1080" pls help me brooChief Blur Buster wrote:Windows Desktop? Please go to "Change display settings" and make sure it's 1920x1080
Aha, monitor is complaining about using 1024x768
I realize your first language is probably not English, but:
Message disappears after 2 seconds and things are okay.
If it is making it hard to begin a match, then....
Two solutions.
Pick one.
- Turn on GPU scaling in NVIDIA Control Panel. Depending on the monitor, it may have more lag or less lag. (In occasional cases, the scaler in the monitor is more laggy, and in other cases, the GPU scaler is more laggy). Test both ways for preferred aim feel.
*OR*
- If you frequent Alt-Tab to Windows, or game does many mode switches, then switch Windows to 1024x768 too at the same Hz. Then the popup won't repeatedly appear. That way, entering and exiting game won't have the annoying effect. You could do this at the beginning of a competitive day and go back to 1080p at the end.
At the moment, some of the 240Hz monitors *might* be less laggy with 1080p than with 1024x768 due to scaling lag, except for monitors with line-buffered scaling. Given a fast GPU (GTX 1080 Ti), you are CPU/network limited in CS:GO so the increase in resolution becomes "free". No lag increases!! Unlike yesterday slower GPU.
Two solutions.
Pick one.
*OR*
