ASUS PG258Q w/ r9 390x
Vechs
Post by Vechs » 13 Jan 2018, 16:46
Hello, I have to ask a question, has anyone got the pg258q working at 240hz with a amd gpu? It dosen't really want to do ''240hz''
I am open to suggestions!
lexlazootin
Re: ASUS PG258Q w/ r9 390x
Post by lexlazootin » 13 Jan 2018, 19:28
Vechs mate, you have to tell us more than this. What do you mean by doesn't want to do "240hz"? The more information the better.
Vechs
Post by Vechs » 13 Jan 2018, 20:00
GPU driver - Adrenalin Edition 17.12.2 (gpu not overclocked)
OS - windows 7 x64
the problem is that the monitor recognises the signal, and then turns off after a secound or two, and then turns back on. It cycles infinitely.
Using provided monitor dp cable.
tried with pixel patch and without it, thats about it.
