Hi guys,
i have a BenQ XL2430T. In the Nvidia Settings i can`t choose 1080p, 1920x1080 (native) with 144hz. I use a displayport 1.2 cable.
I can only choose 1920x1080 144hz.
1080p, 1920x1080 (native) - max. 60hz:
1920x1080 - 144hz:
Does someone know what to do, that i can choose the 144hz with full hd (native) ?
BenQ XL2430T - 1080p, 1920x1080 144hz
- 144hz no fullhd.JPG (87.56 KiB) Viewed 1809 times
- 60hz.JPG (88.82 KiB) Viewed 1809 times
Re: BenQ XL2430T - 1080p, 1920x1080 144hz
These are both the same resolutions. So it doesn't matter. 1920x1080 is 1080p.
However, if it bothers you, you can use CRU to edit your refresh rates:
https://www.monitortests.com/forum/Thre ... tility-CRU
