A question concerning FPS & refresh rate relation
Re: A question concerning FPS & refresh rate relation
Also, What about my question about playing on 200FPS@240Hz ?
- lexlazootin
You get stutters no matter what unless you use G-Sync.
Higher the HZ is almost ALWAYS better.
so I should still go 240Hz even tho the fps in this game is 200 AT MAX ?lexlazootin wrote:You get stutters no matter what unless you use G-Sync.
- lexlazootin
