Can't use low input lag with Ag251fz
Can't use low input lag with Ag251fz. The option just gets greyed out. I have tried updating the drivers, everything. I have used this with a nvidia card and an amd card, low input lag only works with my nvidia card. I don't understand. My amd card is the vega 64.
Re: Can't use low input lag with Ag251fz
This option is grayed out in freesync mode. Disable freesync if you want to use it.
I had the same issue, there was no way for me to fix it unless I made a Custom Resolution but it only worked at 144hz.
even when doing this I can't get it onEemwah wrote:I had the same issue, there was no way for me to fix it unless I made a Custom Resolution but it only worked at 144hz.
makes no difference, I wasn't even running freesync in the first placeRealNC wrote:This option is grayed out in freesync mode. Disable freesync if you want to use it.
