Unsure why, Iv'e unplugged the monitor, Installed the drivers off BenQ's site and it still detects as Generic PnP monitor (I assume this is the problem?)
Its connected correctly through a DVI cable and still isnt showing?
STROBE BUSTER UTIL NOT DETECTING MY XL2411?
Re: STROBE BUSTER UTIL NOT DETECTING MY XL2411?
Keep tuned for Blur Busters Strobe Utility 2.0
I have been rewriting the utility as part of multiple projects I am doing behind-the-scenes.
Version 2.0 is now available.
-- Much better automatic detection of monitors
-- Much better multimonitor support (but must adjust 1 monitor at a time)
-- All strobe-capable BenQ/Zowie monitors supported.
-- Numbers match Factory Menu
-- Full Factory Menu range adjustment
-- Automatic rollback upon hitting Esc key (for old buggy monitors that black out -- e.g. old firmwares + large VT + large phases)
Check out this thread.
