Blur Busters Forums
XL2546 owners + AMD video cards
Postby Falkentyne » 08 Mar 2018, 13:09
Can any XL2546 owners who have current AMD video cards (290X or newer please) please DISABLE DyAc (benq blur reduction) in the service menu and then tell me if FREESYNC becomes available in the AMD settings after power cycling the monitor?
Service menu: Power off, hold button#4 for 5 seconds, power on while holding button 4, then release when a screen appears.
Press button 4 to enter the service menu and disable DyAc.
Then power cycle the monitor.
Falkentyne
Re: XL2546 owners + AMD video cards
Postby Chief Blur Buster » 08 Mar 2018, 16:06
P.S. It's my understanding that Blur Busters Strobe Utility 2.0 can allow you to turn on/off DyAc without needing to access Factory Menus.
1. Launch Strobe Utility 2.0 (or later)
2. Disable the "Enable Strobe" checkbox
3. Quit Strobe Utility
4. Power cycle your monitor.
5. See if FreeSync becomes available.
While the "Enable Strobe" doesn't immediately enable strobing on early XL series, it apparently does on the XL2540/XL2546 series. So that saves trips to the Factory Menu.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Who is online
Users browsing this forum: Google [Bot] and 11 guests
