XL2430 or XG2530
SP4CEBAR
XL2430 or XG2530
Post by SP4CEBAR » 23 Apr 2018, 05:36
They're both the same price in my country(2499CNY 400USD),but i don't know which one is better,i mainly play PUBG and R6,i want low input lag black equalizer just overall advantage over other players,my specs are i7 4770 GTX 1070.
Sorry for the bad english,Thank you guys.
Re: XL2430 or XG2530
Post by Chief Blur Buster » 23 Apr 2018, 18:14
SP4CEBAR wrote:They're both the same price in my country(2499CNY 400USD),but i don't know which one is better,i mainly play PUBG and R6,i want low input lag black equalizer just overall advantage over other players,my specs are i7 4770 GTX 1070.
BenQ ZOWIE XL2430 versus ViewSonic XG2530?
I'll point out the biggest differences.
BenQ ZOWIE XL2430 ViewSonic XG2530
  • XG2530 is 240Hz.
  • XG2530 has official FreeSync support
Most people play PUBG with VSYNC OFF. Which is more optimized for SMTT testing which TFTCentral uses. SMTT results are better than Leo Bodnar Lag Tester results for PUBG and CS:GO players. But they haven't tested both, but I was able to verify that the VSYNC OFF input lag of the XG2530 was low when run in its native 240Hz mode. So, from what I know even thus far -- the absolute per-pixel latency of these two displays is similar (less than 2ms difference) at their own respective native refresh rates. So the lag difference is not the buying consideration here for the majority. The above features will be the deciding factor if price is identical. Be noted the current 240Hz monitors (by ANYBODY) have higher lag at 60Hz and 144Hz, but if you're always at 240Hz, this doesn't matter.
The question is, what features are the most important to you?
SP4CEBAR
Post by SP4CEBAR » 23 Apr 2018, 23:07
thanks for the reply chief!
higher refresh rate is always better right?i won't be using the blur reduction function.they both have the thing to allow you see clearer in darker areas,so xg2530 is the better choice i assume?
