Blur Busters Forums
4K/144Hz Data Rate
4K/144Hz Data Rate
Postby cyberknot » 08 May 2018, 14:02
These new monitors (4K/144Hz) use two DP cables or compression (DSC) with single cable?
cyberknot
Re: 4K/144Hz Data Rate
Postby mello » 08 May 2018, 15:11
1 cable, HDMI 2.0 or DP 1.4
The DisplayPort 1.3 and 1.4 provide the extra bandwidth required for 240Hz at 1440p, 120Hz at 4K, 60Hz at 5K, and 30Hz at 8K. The main difference between the DP 1.3 and DP 1.4, is that the latter supports DSC (Display Stream Compression) which allows it to deliver 144Hz at 4K, 120Hz at 5K, and 60Hz at 8K – but with compression.
HDMI 2.0 can be used for 240Hz at 1080p, 144Hz at 1440p, and 60Hz at 4K. The latest HDMI 2.1 adds native support for up to 144Hz at 4K and 30Hz at 8K.
It is weird that that they didn't use HDMI 2.1 for these monitors though.
mello
Who is online
Users browsing this forum: Bing [Bot] and 11 guests
