asus pg258q color banding
ahmedpc03
Post by ahmedpc03 » 22 May 2018, 15:26
Hi
i have an asus pg258q
and i noticed in some videos color banding in dark ares
my question : is this normal for tn panels (6bit+frc)
is there a way to fix it ?
Re: asus pg258q color banding
Post by RealNC » 22 May 2018, 15:40
Banding is usually already existent in the source material and is not the monitor's fault. If you post a screenshot here, we'd be able to tell.
ahmedpc03
Post by ahmedpc03 » 22 May 2018, 19:01
RealNC wrote:Banding is usually already existent in the source material and is not the monitor's fault. If you post a screenshot here, we'd be able to tell.
thank you
please check the link below
https://drive.google.com/open?id=1ccyOc ... IqIRQjdp2u
Post by RealNC » 22 May 2018, 19:21
That's not what I meant. I meant a screenshot of the banding, not a photo of your monitor.
open
Post by open » 25 May 2018, 23:05
First thing to do is set gamma to 2.4 in the monitors menu. TFT central found this setting to be truer to the desired 2.2 gamma. This will help darken the middle of the brightness curve and reduce contrast in the dark areas that often have banding on encoded video. In exchange the brighter areas will have enhanced contrast and in my experience this is very welcome.
