hi
i bought the benq ex3200r yesterday
and i found a dark pixel visible to look from far distance, and i am just wonder if its dead pixel or not
should i ask for replacement?
please find the attached files
please help : new monitor (dead pixel or not)
- dead pixel 2.jpg (5.36 KiB) Viewed 2674 times
- dead pixel 1.jpg (202.92 KiB) Viewed 2674 times
Re: please help : new monitor (dead pixel or not)
Have you verified it's a pixel issue and not something like dirt on top? Try cleaning it with a damp display cleaning cloth.
Other than that, it's up to you if you want to return it or not. I would, but that's me.
yup i tried to wipe it, no its a pixel issue, iam just wonder if its a dead or smudge or dark pixelRealNC wrote:Have you verified it's a pixel issue and not something like dirt on top? Try cleaning it with a damp display cleaning cloth.
Looks like a dark pixel. It's not dead, but it doesn't seem to be able to fully transition either. Or it could be a dust particle stuck on the pixel (behind the screen.)
If you're still in the 14 days period after buying where you can return a monitor for any reason, then you might as well make use of that. You might not be able to return it later if the monitor doesn't actually come with a so-called "zero pixels guarantee."
ok thanks
i think ill ask for replacement
refund two monitors
the first one with two dead pixels
and the second one with dead pixel and very bad backlight bleeding
any idea for good monitor 32 inch 1080p 144hz ?
