Hello people,
(Sorry for my bad english)
I have one question, i have a xbox one and i research the best monitor with 1 MS.
Can you help me ?
I hesitate with the XL2420Z against Vg248qe.
Thanks
Best monitor 24 1ms for XBOX 1
Re: Best monitor 24 1ms for XBOX 1
The choice of 1ms versus 5ms would not matter for a 60Hz console -- you would not be able to notice the difference with the longer refresh cycles (60Hz = 1/60sec = 16.7ms per refresh). Unless you were also planning to use the same monitor for computer use at 120Hz as well?yipman70 wrote:Hello people,
you should take the XL2411Z, it has 60hz strobed without too much flickering (you can set flash time up to 4ms), and the least expensive of 3 Z series monitors, you will definitely enjoy it.
Thanks for your advices ! i'm a noob in the display word . Can i set flash time directly on the display or on a utility ? Right now i hesitate between xl2411z and xl2411t. Who have the best color panel and best option ? because for 30$ up i can take the xl2411z and soon i will use it for my new computer. thanks guys
