hi
i bought the philips 323E7QDAB to use it as a second monitor for single player games and ps4
my question is which port do i have to use with the pc, hdmi or dvi ?
is there a different in picture quality,text, colors, or input lag between them
thank you
hdmi or dvi
Re: hdmi or dvi
I usually don't recommend HDMI on PC if you have an NVidia card. Very often, you get completely wrong colors that result in a washed-out image. The reason being that the NVidia driver will very often treat displays connected with HDMI as TVs and output a limited color range to it, even though the display expects full color range.
You can't go wrong with DVI. You're guaranteed proper colors.
Re: hdmi or dvi
i found a display port to dvi cable in a local shop
do you think it well be a good performance?
or order a dvi to dvi better?
Re: hdmi or dvi
I'm not sure what you're trying to do here. Your graphics card has a DVI port, and so does your monitor, right? You only need a normal DVI-D or DVI-I cable. You don't need to convert anything.
Re: hdmi or dvi
cant find a dvi to dvi cable in a local shopRealNC wrote:I'm not sure what you're trying to do here. Your graphics card has a DVI port, and so does your monitor, right? You only need a normal DVI-D or DVI-I cable. You don't need to convert anything.
so i have to order it and it well take about 4 days for delivery
Re: hdmi or dvi
Well, I can't guarantee that there won't be any issues with a needless conversion from DP to DVI. I recommend just ordering a normal, bog-standard DVI-D cable, or asking the local shop to get one for you.
Re: hdmi or dvi
in my city computer shops are very bad
and most of the things i order it online
we have a good big electronics shop its called jarir and they offering a good quality product like this cable
http://www.jarir.com/sa-en/non-branded- ... 40443.html
other than that maybe i can find a dvi to dvi cable in some computer shop but it well be unbranded Chinese cables with bad quality
or order the cable online
any way thanks for your help and sorry for the long story
