Monitor Recommendation
Souraishin
Post by Souraishin » 27 Jun 2018, 03:53
Hey folks!
After browsing lately for a while trying to gain some new knowledge about displays, I found the Blur Busters forum page. Up until now all I cared about regarding monitors was the refresh rate and the response time. Having read in-depth explanations of other important aspects such as motion blur reduction, input lag etc. , I realized how shallow my knowledge was.
From here on, I decided to ask for help, which resulted in this first post of mine here :D.
I'm mainly playing fast paced shooters (like Overwatch, Quake).
Color quality doesn't matter to me at all. I need something really fast that won't let me down by being consistently reliable. My budget is 400 Euros.
So according to your opinion, taking every single aspect of your knowledge into account, which is the the best monitor suited for me and my purposes?
TL,DR: The best and fastest monitor for 400 Euros and less ^^
I'm grateful to any helpful answer in advance.
Looking forward,
Souraishin
ahmedpc03
Re: Monitor Recommendation
Post by ahmedpc03 » 27 Jun 2018, 04:43
what is your graphics card
do you have an interesting for VRR, like gsync or freesync ?
144hz tn 1080p monitor would be your best choice for your requirement and your budget
Souraishin
Post by Souraishin » 27 Jun 2018, 04:47
It's a GTX 1070.
Concerning VRR, not necessarily, as long as the main conditions are met (speed etc.) I'll be satisfied ^^
ahmedpc03
Post by ahmedpc03 » 27 Jun 2018, 04:56
my suggestions
asus PG248Q 180 Hz, G-SYNC (if you are interesting)
benq xl2540 240hz
these two monitors on your budget range and a good choices for eSports
ahmedpc03
Post by ahmedpc03 » 27 Jun 2018, 04:58
just wait for the others to give a suggestion for good choices also
Post by RealNC » 27 Jun 2018, 06:05
Virtually none of the high-refresh (144Hz or higher) gaming monitors will "let you down". They all have very low levels of input lag and are very much suited even for high level competitive play. So my recommendation would be to look for a monitor that has the features you want and good image quality. If the reviews for the monitors that make it on your "look at" list don't mention any weirdness with input lag, then you should be good to go.
TheTechGuy
Post by TheTechGuy » 11 Jul 2018, 04:09
Given the information you've provided I would definitely recommend the benq xl2540 240hz. There are others that could do the job but I doubt to the same quality as the benq.
