Hey all. Does any of you have experience with this model? Store told me it is a new model. But maybe someone has already experinece with it. In Europe it goes for 350 euros which is great price for 1440p 144hz.
Prod.num.: UM.HX0EE.C03
27" Acer XF270HUCbmiiprzx Gaming
Re: 27" Acer XF270HUCbmiiprzx Gaming
That's the XF270HUC
The lowercase letters are identifying features (I forgot the Acer code, it's like a "geekcode" of sorts to identify monitor features)
Google the XF270HUC and it's pretty much the follow-on to the XF270HU series.
Acer XF270HU - TN panel
Acer XF270HUA - IPS panel
Acer XF270HUC - TN panel
As long as you're OK with TN, it's a _really_ good European price for 1440p GSYNC. Only 350 Euros is good for 1440p GSYNC.
Where did u find it has Gsync? I think it does not. I was wondering about the panel used. But I assume it will be the same as other 27” 144 hz displays.
It's has freesync, not g-sync.
Anyway, there's no reviews out there it seems, so your guess about this monitor is as good as ours.
I know, however, you are the experts on this kind of stuff so you may know what to expect from the panel and so on.
