hi
i was looking to replace my monitor for a long time to check which one is the best for me, and i decided to get the viewsonic xg2703-gs, but actually this monitor is not available to buy online from a long time, amazon,newegg, or bandh
and there is a little sellers with overpriced since its not available
if there is any one have an information for this monitor availability date, ill be appreciated to let me know pls.
thanks
viewsonic xg2703-gs discontinued
hey guys
just FYI
the ViewSonic Customer Service confirmed for me thru my email sent to them, the viewsonic xg2703-gs is discontinued
i was looking to buy this monitor from a long time but its not available any more, just found some Australian websites selling this monitor with reasonable price.
according to the reviews, this monitor handling the response time very well!
https://www.youtube.com/watch?v=qgxU3wd1Zc4
https://www.youtube.com/watch?v=dQe_I9b3pVk&t=59s
can we see a micro led gaming monitors soon ?
just FYI
Re: viewsonic xg2703-gs discontinued
You can still buy it in Europe.
yeah you are right
and it well be a good chance to buy it for the people whose living in Europe and close to
for me personally i found it a little bit pricey on amazon uk and some of the others online shops, compared to the original price, + shipping is going to be over priced to my country.
There's three other monitors with the same IPS panel though. The Acer XB271HU is one of them and seems to be available at a decent price.
iam just worry about the ghosting from this monitor cause i saw many complains about that like this one ?RealNC wrote:There's three other monitors with the same IPS panel though. The Acer XB271HU is one of them and seems to be available at a decent price.
https://www.youtube.com/watch?v=e7M8EkAJINE
do you think this is normal for 4ms ?
i asked this guy about the fps during his video, he said it was between 70 and 80 with gsync enabled (gtx 1080)
he said when he disable the gsync, there is no noticeable ghosting at all
monitor without gsync is not usable for me, i cant use it with tearing and stuttering
i tried your trick couple days ago trying to use it, capping the fps with the 143.9... , with vsync on but the input lag is also not acceptable for me
That looks like trolling to me. Or whoever uploaded that video has a defective unit. But I suspect trolling. If you record video from a monitor in a dark room you get a lower shutter speed, and any LCD monitor will look blurry.ahmedpc03 wrote:iam just worry about the ghosting from this monitor cause i saw many complains about that like this one ?
This monitor has the same panel as the ViewSonic (just a slightly different revision,) and performs very similarly. The other monitors with this same panel are the Asus PG279Q and the AOC AG271QG.
Re: viewsonic xg2703-gs availability
RealNC has an XG2703-GS.
It is my understanding that this specific model is discontinued, but you can get similar panels -- check the "165 Hz IPS" panels (they all use the same panel) in the monitor list below:
