Discuss the upcoming generation (August+) 2018 monitors
Re: Discuss the upcoming generation (August+) 2018 monitors
That's what I'm hoping for also. That ULMB can be used at 240hz. I would also assume lower G2G's would help higher resolutions cope with higher framerates too, such as introducing 240hz to 1440p.
Yes, true 0.5ms GtG makes a quite noticeable improvement to non-strobed 480 Hz and strobed 240Hz.RealNC wrote:There will be no change for normal operation. For strobed operation though (motion blur reduction modes) this should really minimize crosstalk, or even eliminate it completely. I hope.Q83Ia7ta wrote:How you guys think will that 1ms -> 0.5ms change be good noticeable like 144hz -> 240hz jump?
Improvements to non-strobed 240Hz will be fairly marginal for most, but not undetectable for the discerning.
It is indeed true that faster native GtGs produce better overdrive algorithms (fewer coronas and ghost-trail artifacts), especially improved variable-rate-overdrive (overdrive tuning that continually vary depending on game's framerate -- that's why GSYNC often looked better than early, older FreeSync monitors before FreeSync 2).
Good faster native GtG will reduce the overdrive-aritfacts-differential between 30fps-vs-60fps-vs-120fps-vs-240fps, requiring less/easier custom overdrive tuning that needs to dynamically vary based on frame rate.
Some people are very sensitive to blur asymmetries (ghosting/coronas and imbalances between left-edge/right-edge blur trailing during horizontal panning motion). Much like some are sensitive to color, or brightness, or flicker, or inversion artifacts, or input lag issues. Everybody is different in their sensitivities to monitor artifacts.
0.5ms GtG will help upcoming 1080p 480 Hz monitors (ETA ~2020) and/or strobed 240Hz (now available in non-ULMB variants).BlurZapper wrote:That's what I'm hoping for also. That ULMB can be used at 240hz. I would also assume lower G2G's would help higher resolutions cope with higher framerates too, such as introducing 240hz to 1440p.
Monitor manufacturers need to read Blur Busters Law: The Amazing Journey To Future 1000Hz Displays. I already know full-HD 480Hz is in development to arrive within three years or so, so disbelieving manufacturers need to read-and-weep and get on the bandwagon. Winky-wink.
(Readers: Don't wait. It's still a long R&D. Buy a monitor today. Clickies below to support Blur Busters.)
Micro-LED is likely years away from consumer use.ahmedpc03 wrote:iam interesting to see the new technology of the panels (micro led) that well replace the oled.
and it well be available on the market by the end of this year and well be more available in 2019
hope to see a gaming monitor using micro led soon
oled is 0.01 ms response time which is almost 0, and hope the micro led well be the same thing
Display maker AUO has a working 8 inch prototype but;
https://www.microled-info.com/auo-has-b ... uction-yetAt the company's recent earning report, AUO disclosed that it does plan to use micro-LEDs in niche products in the future - but following years of R&D, micro-LEDs are still too expensive and are not ready for mass production yet.
The Samsung MLED "The Wall" was hand made, there is no factory or tooling to mass produce this technology, even if Samsung puts out a MLED TV in 2019 or 2020 I would expect availability to be extremely limited.
