Hello everybody
I have a question about the Blurbuster Strobe Utility, I own the benq xl2546 and I was happy with it, but then I got to your page through friends and read a bit about this tool. Then I downloaded it and tested it, now is my question. How do I reset my screen to Factory Mode?
When I turn off the "Enable blur reduction adjustments" tool is this again in Factory Mode? Or not?
thank you for your help
Benq xl2546 Question
Re: Benq xl2546 Question
To reset to original settings, you'll want to reset everything to Factory Defaults.
See this thread -- viewtopic.php?f=13&t=2467
The tool helps -11 / -20 / -30 users much more than -40 and -46 (XL2540, XL2546, XL2740) but if you want to test further with improved strobe quality (reduced strobe crosstalk), test the 182Hz mode at www.blurbusters.com/crosstalk
