AW2518HF not running at 240hz
Posted: 12 Sep 2018, 17:05
by Bobo
As the title says, my AW2518HF is not running at 240hz, instead its running at 239hz.
And if i set it at 144hz, it runs at 143hz.
Any idea on what the problem might be?
Re: AW2518HF not running at 240hz
Posted: 12 Sep 2018, 17:36
by RealNC
How do you know what it's running at?
Posted: 12 Sep 2018, 17:40
by Bobo
You can just check the advanced display settings in windows.
https://gyazo.com/2adcfb6896fec21853ed914f51c93186
Posted: 12 Sep 2018, 17:54
by RealNC
Windows will just truncate the true value. If it's 239.9, it will just say 239.
Posted: 12 Sep 2018, 18:11
by Bobo
interesting, did not know that.
But if i make a custom rez with the Toasy app it will show 240hz in windows as well .
Posted: 12 Sep 2018, 18:21
by RealNC
Bobo wrote:interesting, did not know that.
Well, you can always just test your refresh rate here (let it run for a while to get more accurate results):
https://www.testufo.com/refreshrate
What does it say after about 1 minute or so? Make sure nothing else is running on your PC. Also don't have any tabs open in your browser that can interfere (like youtube.)
Posted: 12 Sep 2018, 19:29
by Bobo
239,7
Posted: 12 Sep 2018, 21:12
by Bobo
Another thing is, the image is kinda grainy.
When i first got it, all was good and then i replaced the hdmi cable with DP and this grainy shit happened.
Later i swapped them back but the grainy image still remained.
