DELL 3007 WFP-HC: bad for gaming, ie. worth replacing?
Posted: 16 Sep 2018, 12:06
Hello!
I'm currently using a DELL 3007 WFP-HC monitor, IPS panel, 60 Hz, decent colors, decent picture, some buzzing, lots of motion blur.
My impression is that it is not too good for gaming because of the following reasons:
1.) blur
2.) too high resolution (2560x1600) for my budget gfx card, which requires me to play at 1920x1080 non-native (!) resolution, which isn't a problem lag-wise, because there is no complex scaler built in AFAIK (if at all), but it certainly does not improve the picture quality.
3.) non-variable frame rate that possibly makes games look choppier than needed when the 60 fps cannot be reached.
4.) tends to give me quite a bit of eye strain.
For those reasons I consider buying a second monitor for gaming.
Are there 27" 1080p FreeSync/G-Sync budget monitors that are considerably better for gaming, esp regarding the points listed? i.e. was someone able to compare them personally or even side by side? 25" or even 24" would, maybe, still be acceptable, tho I'd prefer to stay at 27".
I currently have an nVidia gfx card, but it's unstable and I'm gonna upgrade the PSU next to check if I need to replace the card. For that reason I don't know yet whether it has to be a G-Sync monitor or a FreeSync one. If I have to buy a new gfx card, it will be a decision based on prices, and it seems AMD/FreeSync currently has an edge there.
1.) blur
