AOC AG251FG issues
Posted: 13 Oct 2018, 19:38
Hello,
I bought AOC AG251FG (240Hz, G-Sync) monitor and I am experiencing following issue:
More samples here: https://imgur.com/a/GoWKeWr
All captured with a phone at crappy angles, I know.
This looks like some kind of signal noise to me, but I'll leave it to You.
This happens mostly in the right part of the screen as shown, but often there's also a thin horizontal line somewhere near the bottom as well. Unsure what conditions needs to be met for this to happen - although it looks a bit random, I noticed it happening more frequently in presumably low FPS moments, like score board or loading. This includes Windows 10' welcome screen, when user profile is loading.
Rarely there's also part of the screen displayed in different place:
Is this something known and can be done with, or this unit is simply damaged and should be returned / replaced?
Here's some background information:
- Tested on both new PC (Win10, GTX 1080 Ti, latest drivers) and previous PC (Win7, GTX 970, few months old drivers)
- Used DisplayPort cable included with the monitor. For test tried replacing the cable with other DP - ended up with blank screen. However, local shops ran out of DP cables, so I got random one, uncertain what version of the cable - might not suit the needs, therefore may be irrelevant.
- 240Hz setting in Windows, G-Sync enabled for both windowed and fullscreen.
- In monitor OSD: Overdrive set to light, Shadow Control set to 0.
