Ultrawide monitor for fps gaming pros and cons.
skogsmus
Post by skogsmus » 14 Oct 2018, 04:56
34/35" ultrawide 3440x1440p
Has someone played fps games on them?
What do you think.
Give me your pros and cons.
k2viper
Re: Ultrawide monitor for fps gaming pros and cons.
Post by k2viper » 15 Oct 2018, 12:38
I played some Overwatch on a ultrawide screen, but this game dont have true 21:9 aspect support, its 21:9 is a vertically cut 16:9 so it doesnt give you a wider FOV.
My impressions may be mostly negative because of that. Anyway, currently I think the wider you go, the harder you get any benefit not in static view case, but in action. VR headsets are also not going ultrawide.
Post by RealNC » 15 Oct 2018, 13:43
skogsmus wrote:34/35" ultrawide 3440x1440p
What do you think.
Well, you can get an idea yourself by adding a custom resolution. On a 1440p display, you'd add 2560x1080. On a 1080p, you'd do something like 1920x824. In your driver control panel, you then select GPU upscaling and "keep aspect ratio".
