Ghosting on AW2518HF
I've had the AW2518HF for a while now and this issue has been bugging me. I even got the panel replaced and still have the issue and have come to accept it. I saw people posting custom resolutions setup with CRU so I thought maybe those would be able to fix the ghosting issue. Basically when things are moving across the screen I can see a faint outline of where they just were. This occurs more so on 240hz than just 60hz. It also becomes even more exaggerated if I put response time on super-fast rather than normal. This was the page I was using to examine the issues.
Re: Ghosting on AW2518HF
I have this monitor but i never suffer from ghosting could be you have bad firmware the only thing can fix it using freesync
And dont use supet fast overdrive only fast
That test is designed to always expose this flaw. Every LCD monitor has at least some ghosting. The test is there to show how much ghosting a monitor has, not whether it has any or not.MrMOABy wrote:This was the page I was using to examine the issues.
