Having trouble getting 144 hz on my BenQ2411Z
Posted: 10 Dec 2018, 01:28
by Tayoesicc
Just bought a new GPU (RTX Windforce 2070) and it does not have a DVI Input on the card only DisplayPort and HDMI. Do I need a converter from Display to Dual Link DVI or will a HDMI or DisplayPort Cable that supports 144hz work? (If so which ones) Thanks.
Re: Having trouble getting 144 hz on my BenQ2411Z
Posted: 10 Dec 2018, 02:56
by RealNC
AFAIK, the BenQ 2411Z only supports 60Hz with HDMI. So it seems you need a DisplayPort to Dual DVI adapter.
However, wait to see if someone else here knows better than me, because these adapters are not very cheap. Active adapters are rather expensive, and I don't really know if you'd need an active or a passive one.
Posted: 10 Dec 2018, 14:56
by Tayoesicc
Just to add on does anyone know if the xl2411p has displayport at 144hz. My brother has one but he got a DVI cable with his but I look online and it seems like DisplayPort @ 144 should work. Thinking of just swapping the two monitors.
Posted: 11 Dec 2018, 02:47
by RealNC
The specs advertise DisplayPort 1.2, so yes. It should support 144Hz.
