Anything I can do to reduce the inverse ghosting of XL2411P?
jadefire5643
Post by jadefire5643 » 12 Dec 2018, 12:42
It only has two overdrive (AMA) settings: High and Premium. Both of them produce noticeable inverse ghosting (coronas), but especially so on Premium. Keeping the setting to off is bad because the regular ghosting is there, and the input lag is much higher. Premium offers the best response time, but the inverse ghosting is really annoying. Any ideas?
ELK
Re: Anything I can do to reduce the inverse ghosting of XL24
Post by ELK » 12 Dec 2018, 12:47
My acer xb has a service menu where I can set overvoltage from 0 to 255. Have you looked in your service menu?
I don't see xl2411"P" but maybe one of these will work.
viewtopic.php?f=2&t=2467
jadefire5643
Post by jadefire5643 » 12 Dec 2018, 15:07
ELK wrote:My acer xb has a service menu where I can set overvoltage from 0 to 255. Have you looked in your service menu?
It says that you need to enable blur reduction, but I found out that I am flicker sensitive. I can't use blur reduction for more than 1 hour before my eyes get fatigued and I see flickering lights on my retina :(
Post by RealNC » 13 Dec 2018, 00:00
Nope. Overdrive (your monitor calls it "AMA") is not configurable by the user other than what you get in the OSD.
Keep in mind that the colder the panel is, the more ghosting it has. Is it especially cold where you live?
jadefire5643
Post by jadefire5643 » 13 Dec 2018, 16:05
Do you guys know some good 144hz monitors without inverse ghosting issues, but with great response time still? I can still return this monitor, but I don't know what else to get.
Post by Chief Blur Buster » 13 Dec 2018, 18:11
AMA granularity is very limited.
However, if you use blur reduction with Blur Busters Strobe Utility (or the factory menu), try the large vertical total trick as it can enlarge the crosstalk-free zone. Specifically, VT1502 works on XL2411P.
konchy
Post by konchy » 14 Dec 2018, 00:35
Dear OP,
Please let me know how the large vertical total trick works for you. I was considering buying the same monitor.
Thanks!
